Shower niche, make my own?
Tony K
Hi all.
I am about to build a bathroom in our SB. One wall of the bathroom, where the shower will go, is block work with waste pipes etc mounted on it. I intend to fix timber battons to the block, then fix tile backer boards over the top before tiling.
As there is a cavity between the timber battons I am considering exposing a section, thereby creating a niche.
I have seen lots of ready-made shower niche kits that slot into stud walls, but they are not to the size I want.
Am I OK to simply create a niche space between timber battons, mount tile backer board around the inside, and tile the area? I would find some way to create a tiny fall into the shower area at the base of the niche, but otherwise see no reason not to proceed.
Am I missing anything?
Thanks
