fisherman 72 Posted January 5, 2024 Share Posted January 5, 2024 Hi. I am in the wet SW of Cornwall. As my name suggests, lobster fisherman, boatbuilder, retired. Did this 1870 cottage up from near derelict in 1985. Been rectifying faults from builder friend ever since, from the inspection chamber one brick too small, to the roof tiles not quite covering the top of the wall. In 2005 got my Not Very Qualified 2 as CSCS chippy, when winter fishing got too tough for my age. Then realised how many things were wrong! Any old how, can I pick your brains straight off, for which I apologise. I did this low pitched tile roof over a porch, fibre cement 200x400 tiles, 16degs. 35 years on have leaks and rotten battens. I am going to strip it. Remove tight membrane. Install slack membrane. Battens on rafters, cross battens. The question is about using one of the low pitch roof products by Permavent. There is the rubber gasket under the tile edge, expensive, or the plastic metre long x 220mm along the battens, not so deep. Or is it possible to simply cut a 400mm strip of membrane and fit it under each row of tiles? Thanks for looking, any help appreciated. Link to comment Share on other sites More sharing options...
SteamyTea Posted January 5, 2024 Share Posted January 5, 2024 Welcome Can't really help with the roof question. Pictures may help others though. (Just about to pop into PZ as it seems to have stopped raining) Link to comment Share on other sites More sharing options...
ToughButterCup Posted January 5, 2024 Share Posted January 5, 2024 Hi. You are most welcome. Other Corns will be along drekly. 😑 You are more likely to get an answer to your question if you post in the roofing section here . ( Because there'll be others who have ( or have had ) the same issue. Just copy and paste the question bit of this post into that thread on the site. Any images or diagrams ( or product images) you make ( photograph them) and put on here will help us help you. Link to comment Share on other sites More sharing options...
fisherman 72 Posted January 5, 2024 Author Share Posted January 5, 2024 Thanks, will do, when I can crowbar granddaughter off the main PC as I can't do pics on this phone. Or maybe she will show me how to..... Link to comment Share on other sites More sharing options...
