40v to 12v
Strawman
You def need some sort of charge controller, or the batt will die  - the cheap ones tend to be PWM only - I think they're fine if the panel is about the right voltage for the battery.  MPPT will perhaps double the current (hence power) output from the panel - eg this one:
https://uk.renogy.com/renogy-rover-20-amp-mppt-solar-charge-controller/?Rng_ads=03b67fab5b39c2aa&kw=&ad=&gr=&ca=20759790391&pl=ga&gclid=Cj0KCQiA6vaqBhCbARIsACF9M6n-o8GFD95rBOJdUawQzalez1l8EGmQBSzacZ-BLyoECsXhTQDmfC0aAr2iEALw_wcB&gad_source=1
Only you can decide if it's worth the extra money!
