Up and running
I Took a oic this morning.
Which gives
SAP  73.6%
PHI   76.9%
I adjusted the incoming air to within 2,5% of each other. Life is to short to strive for better.
I left things for a few hours and took another.
Which gives
SAP  71.2%
PHI   80.8%
Making the SAP findings a bit lower and the PHI findings a bit higher.
Is it better or worse?
  • Replies 50
  • Views 8.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • The labels are a little confusing, but I think I can work them out by their relative values.    One way of calculating efficiency of the heat exchanger (although it's not perfect as a poorly
  • I had hoped some wise person  would have commented on the efficiency or lack there of. So in the absence of that I searched for a formula online. I found a formula for a PHI test. My house is now
  • They are usually centrifugal EC fans which tend to be manufactured as OEM for inclusion into other supplier's products and so aren't quite so readily available directly to end users. They can be found
Posted Images
