See page 16:
https://www.sauresta.com/static/files/3/54/354/Dumtraukiu_instrukcija_EN_Rasu_2018-10-26_No7.pdf
Surround with rockwool firerock + minimum spacing to combustibles.
Then use a silicone seal membrane (stretchy) to seal against the flue / join to your airtightness layer:
https://dumtakis.lt/sandarinimo-detales/356-dumtraukio-prasiskverbimo-manzetas.html
I'm going to back that up with some cement board and high temperature sealant to avoid it being a weak point for mice to come visit in our place. It's stick built. Swap the OSB for the fireproof cement boards local to the flue. Use high temperature silicone type sealant between flue and the cement board. Then go over the top of both with the silicone seal membrane taped onto the airtightness layer.
Low / high temperature tape is required for joining that membrane to others if it is at roof level. e.g.
https://dumtakis.lt/sandarinimo-detales/841-klijavimo-juosta-delta-multiband-m60.html
