Robster 1973 Posted November 12, 2023 Share Posted November 12, 2023 Has anyone had any experience with a Section 50 licence? In particular if New Roads and Street Works Act 1991, Highways act 1980 is been correctly applied by Staffordshire county council here. I have made application to excavate the high way to connect a property I am building to Severn Trent foul and surface water drains. However I am informed by Highways and the built country that I need to apply and pay for two licences. I am of the opinion that this is excessive because there is not twice the work for highways to do to issue the licences. -One trench will be dug to connect to both drains which are adjacent at the same time. -The drawing and maps submitted for each licence would be identical. -Severn Trent will make one inspection of the work prior to adoption. -The contractor I have appointed also says one licence is required. Link to comment Share on other sites More sharing options...
Jilly Posted November 12, 2023 Share Posted November 12, 2023 Not sure of the terminology, but the procedure when I did water and electric connections was that I had to pay for both, then water claimed the difference from electric because they shared the trench and then they reimbursed me. As I understand it they make you pay for both in case of a stuff up, so it's your risk if two digs are needed, but in practice it should be ok. I had to deal with both companies and pay for both connections before they would liaise and share the info about the road closures etc. Link to comment Share on other sites More sharing options...
