3 minutes ago, Coanda said:
Would it be feasible to supply or exhaust through these on a slate roof.
Can’t see anything wrong with venting to roof, supply would need careful location to avoid pulling in any chimney emissions or smellies from top of soil pipes etc.
  • 3 weeks later...
I have these fitted on my concrete tile roof, there is another model to use for slate depending on slate size. Do a search for Manthorpe Slate Vent 300 x 600mm / 500 x 250mm.
I'm getting smoke coming in via my supply roof vent from 2 houses away. So, be very careful.
Since I posted this, I contacted the company which fitted them. A very helpful lady texted me back in minutes to say that the vents fitted to my roof are C5.
A quick search online tells me that C5 vents are good for 2000mm2 of air.
My schoolboy mathematics tells me this is more than ample for the 125mm round intake/exhaust pipes I will be using. (correct me if I'm wrong.)
I have located two vents in close proximity to where I will place the exchanger.
Unfortunately they are both intersected by a rafter. This makes things a little more awkward, but I have fashioned vents which will straddle the rafter and seal against the felt.
I will monitor the installation and should any problems arise,  I can change them to the soffit which will be a bit more work, but hay, ho if it's needed.
