Caddy Posted October 23, 2023 Posted October 23, 2023 Hello, does anyone know if you can use a secondary return connection on a UVC as temperature/thermostat insert point. Can the "pockets" you can buy screw into these connections or be made to fit somehow? Thanks
JohnMo Posted October 23, 2023 Posted October 23, 2023 The normal point you add probes to are sealed so water doesn't leak. So you would have to find a thermal pocket to insert first. But remember you have to be deemed competent (i.e. Certified) to work on an UVC.
