jugglesm Posted October 21, 2023 Share Posted October 21, 2023 Hi all, I'm just finishing off the stud wall for my first ever wet room. I'm using 12mm STS construction board and hoping to construct an alcove within the stud to house showergel/shampoo bottles. Couple of questions: 1) Can I just butt STS at 90 degree angles to create my inside and outside corners? or do I need some form of angle bead? 2) Should I just tank the floor joints or do I need to waterproof the cement fibre boards floor to ceiling? if so what product should I use and is taping joints necessary? Many thanks for any help Link to comment Share on other sites More sharing options...
Conor Posted October 21, 2023 Share Posted October 21, 2023 Not an expert on the boards you are using but we used plasterboard. Just fitted as normal, we're taped and filled, the used a mapai tanking kit. You have to use tape on all the joins and corners. Floor to splash height all round. Then two coats of tanking paste. I left the tiler to do the alcove as I didn't have time... I don't think he did a good job as looks like the ply underneath is getting wet and swelling. Alcoves really important as you'll have water sitting their for hours. Link to comment Share on other sites More sharing options...
jugglesm Posted October 24, 2023 Author Share Posted October 24, 2023 thanks, interested in any more advice on this particularly specific to cement fibre boards Link to comment Share on other sites More sharing options...
