Purchased a burner for man cave/shed need advice for insulated flue! thank you
IronBeefa
Purchased this burner from eBay ( I know not the best) but will hopefully serve the purpose for the mancave, it has come with a non insulated flue and I need to put the flue through an insulated roof and wood therefore I need to get an insulated flue that will fit.
dos anyone know what would be the best flue to get and what I can use to convert the size of this one into the insulated one? and if anyone could send me a link that would be much appreciated
Thank you!!
Those sizes look a bit odd. It's generally 4", 5", or 6". Should be a snug fit between sections.
Single wall is cheap and throws out a fair bit of heat. But you can't have it within a certain distance of combustibles. Twin wall can be pretty close to combustibles (~2" from memory).
Non combustible includes masonry and cement fibre board.
It's not rocket science but the rules are there for a reason and the consequences of getting it wrong are pretty bad.
