wozza Posted October 19, 2023 Share Posted October 19, 2023 Hi All, We had UFH fitted to our existing heating system around three years ago. AT the time I asked the installer if we needed an expansion vessel and he said nope you should be ok - I questioned him again a few times to be told no, it should be fine - so we never fitted one, even though lots of people on here said we should have one. 3 years later and all has been fine until today. I fired up the heating for the first time since March - everything was working ok - Rads got warm, UFH all working and warm - I then checked the boiler and we had suffered a small leak of water from inside the boiler - I estimate around a cup full, and no more has leaked out - heating still working fine. I then noticed that the system was running at 2.1 bar - it used to run at around 1.6 to 1.7. So I drained off some water to reduce the pressure but anything lower than 1.9 bar and the boiler stops working and displays an F75 fault. I have topped the system back up to 2.1 bar the the fault has reset and everything works great. The boiler is a Vaillant Ecotec Plus 831 and it was fitted in 2010 and it has never missed a beat - we have 9 rads and 6 UFH loops - I have an engineer booked to come and look but thought I would ask the brainiacs here if a few questions so I could be better armed. Do you think the boilers expansion tank is knackered? Do I need an extra expansion tank? If so then how do I size it and can it be fitted anywhere on the return? If I do need an expansion tank, does anyone have any suggestions for a wall mounted one Thanks all, Wozza. Link to comment Share on other sites More sharing options...
JohnMo Posted October 19, 2023 Share Posted October 19, 2023 We had similar issues in our last house, the diaphragm in the expansion had failed. The plumber should just replace like for like. 1 Link to comment Share on other sites More sharing options...
wozza Posted October 25, 2023 Author Share Posted October 25, 2023 Turns out that is was the expansion tank (only a small leak though as there wasn't much water in it), and the pressure switch was sticking - both replaced and working like it should. Link to comment Share on other sites More sharing options...
