Jambutty Posted October 18, 2023 Posted October 18, 2023 Bit of a silly question. Probably no best way but here goes. I have a BROOKVENT airstream Ace MEV with 1 x 125mm external connection and 11 75mm inlets. I can position the fan so the 125mm can extract directly outside with no bends and a 1.5m duct run but all 75mm ducts will have to be approx 2m longer Or I can position it and use 2 125mm 90 elbows with approx 3.5m of external duct length but all 75mm ducts will be 2m shorter Will it actually matter or am I over thinking it
JohnMo Posted October 18, 2023 Posted October 18, 2023 You really need to do the math. Look up the allowable pressure drops for your system, then look at the pressure drops across the different duct sections and any bends. Otherwise it's all guess work, rubbish in rubbish out.
