Square Feet Posted October 12, 2023 Posted October 12, 2023 Hi, can anyone tell me which valves I need for a towel radiator that is used as the safety radiator in a combi GCH system? All the ones I can find seem to be thermostatic which won't be what I need I think.... Cheers
JohnMo Posted October 12, 2023 Posted October 12, 2023 So the radiator is always open when the CH is on? The radiator would have just the normal lock shield valve and a manual valve. Or you add a automatic bypass valve between the flow and return from the boiler.
Square Feet Posted October 12, 2023 Author Posted October 12, 2023 Hi John, thanks for your reply. Yes it's the one rad in the system that needs to always be on. I just wasn't sure what valves (if any) I needed to fit. It's going to be rented out and I don't want the tenant to be able to turn it off somehow. So just something like these? https://www.ebay.co.uk/itm/384102627619
