AliMcLeod Posted October 11, 2023 Posted October 11, 2023 (edited) Hi, Does an AC coupled PV install with a 3.6kW inverter and a 5kW battery require a G98 or a G99 application? I originally thought it was G98 but installer is saying G99 (so will delay the install). Happy to wait for it, but just interested. Is it because it's AC coupled with a batter ? 3.6kW even though the inverted is 3.6kW? Edited October 11, 2023 by AliMcLeod
JohnMo Posted October 11, 2023 Posted October 11, 2023 Depends if everything including the battery is all done with a single hybrid inverter, G98, as the system cannot export anymore than the inverter rating. If you have PV and battery with seperate inverters G99 as you can exceed the G98 limits.
AliMcLeod Posted October 11, 2023 Author Posted October 11, 2023 It is a 3.6kW Solis String Inverter and separate 5kW Puredrive AC battery system.
JohnMo Posted October 11, 2023 Posted October 11, 2023 So it requires G99 as per your installers statement
