RachelG Posted October 10, 2023 Posted October 10, 2023 I am seeking a planning consultant in the central belt of Scotland who has a genuine passion for sustainable development and has a proven track record of successful planning applications. Should I only be using those registered on the RTPI directory or are there other recognised bodies? Other than trawling through past planning applications of similar developments, can anyone suggest other ways to select a suitable consultant? Does anyone have any particular recommendations?
Indy Posted October 10, 2023 Posted October 10, 2023 5 minutes ago, RachelG said: Other than trawling through past planning applications of similar developments, can anyone suggest other ways to select a suitable consultant? No direct suggestions but I'd heavily suggest going down this route. Find consultants who have dealt with your LPA, have some sort of relationship with them and understand what they want, which format they want it in etc. Local knowledge can be incredibly helpful in shaving off valuable time.
Alan Ambrose Posted October 10, 2023 Posted October 10, 2023 Maybe my LPA is a bit different - but they don't seem to care much about 'sustainable' in practice - although, of course, their policies enumerate it. My model is that planning (for dwellings anyway) is 'look and feel' only. So, I wonder whether you need a good planning consultant rather than one with 'sustainable' qualifications. That makes the net wider. I'm assuming that you're not going for a para 80 home in the wilderness - correct me if you are.
nod Posted October 10, 2023 Posted October 10, 2023 Go on your local planning and look at the successful applications Start withe the ones with lots of conditions Trees floods etc You will find the same name cropping up
