JohnBishop Posted October 9, 2023 Share Posted October 9, 2023 Hi All, I have a cranked roof and I was initially thinking about fitting 25mm Celotex into the gap to address the thermal bridging however there are joists protruding and I think in most cases I won't be able to squeeze in Celotex. Can I use SuperFoil instead? Best Link to comment Share on other sites More sharing options...
nod Posted October 10, 2023 Share Posted October 10, 2023 Superfoil is ideal for this From memory = to 60 mil of pir 1 Link to comment Share on other sites More sharing options...
Redbeard Posted October 10, 2023 Share Posted October 10, 2023 Check the spec for whatever multifoil you have in mind, as there may be battens required for air-gaps either side, so thin might = 'fat' after all. 1 Link to comment Share on other sites More sharing options...
JohnBishop Posted October 10, 2023 Author Share Posted October 10, 2023 7 hours ago, Redbeard said: Check the spec for whatever multifoil you have in mind, as there may be battens required for air-gaps either side, so thin might = 'fat' after all. Last time I have ordered Superfoil but it was floor insulation so this one will be different. I look at these https://www.builderdepot.co.uk/?q=superfoil There is breathable Superfoil SF19BB: https://www.builderdepot.co.uk/1200mm-x-10m-superfoil-sf19bb-breathable-multi-foil-insulation?queryID=2263a3e602ffb7156e458879776cdf73&objectID=40602&indexName=production_default_products# and a bit more expensive SF40 https://www.builderdepot.co.uk/1500mm-x-10m-superfoil-sf40-multi-foil-insulation?queryID=2263a3e602ffb7156e458879776cdf73&objectID=22352&indexName=production_default_products In my case the rafters are about 33-37cm apart and the cranked bit is about 70cm deep/long so the only thing I can do is to cut ~35cm W and 80cm L Superfoil strips and slide them into the void then staple on top unless there is a better way. Link to comment Share on other sites More sharing options...
Redbeard Posted October 10, 2023 Share Posted October 10, 2023 What does the manuf'r say about air gaps on either side (i.e. top and bottom) of the insulation? Can you comply in the space you have? Can you get it air-tight? If it is only stapled, and you cannot get in to get air-tightness tape on then there is a good chance that it will just be something shiny sitting in a breeze. Link to comment Share on other sites More sharing options...
JohnBishop Posted October 10, 2023 Author Share Posted October 10, 2023 42 minutes ago, Redbeard said: What does the manuf'r say about air gaps on either side (i.e. top and bottom) of the insulation? Can you comply in the space you have? Can you get it air-tight? If it is only stapled, and you cannot get in to get air-tightness tape on then there is a good chance that it will just be something shiny sitting in a breeze. I cannot find this information. Their installation manual is loaded with colours, my eyes hurt. In that case it does not make sense to put it in because there is no access to attach it at the bottom. It says in the manual that for over rafter installation full roof strip is required. On the other hand under rafter installation does not make sense because I want to insulate just the cranked bit not the whole roof e.g. for loft extension Link to comment Share on other sites More sharing options...
JohnBishop Posted October 11, 2023 Author Share Posted October 11, 2023 21 hours ago, Redbeard said: What does the manuf'r say about air gaps on either side (i.e. top and bottom) of the insulation? Can you comply in the space you have? Can you get it air-tight? If it is only stapled, and you cannot get in to get air-tightness tape on then there is a good chance that it will just be something shiny sitting in a breeze. I understand this cannot be airtight but I don't feel a breeze in that space moreover foil reflects the heat otherwise people would not use foil blankets outdoors. Ideally you want to be perfectly wrapped in it but it still works even if it isn't. Link to comment Share on other sites More sharing options...
