jayc89 Posted September 29, 2023 Posted September 29, 2023 Osma seem to do two different products; Osma Weld and Osma Waste Solvent Weld. https://www.travisperkins.co.uk/solvent-weld-waste-pipe/osma-waste-solvent-weld-waste-system-white-knuckle-bend-50mm/p/818158 https://www.travisperkins.co.uk/solvent-weld-waste-pipe/osmaweld-90-knuckle-bend-white-50mm/p/173119 One's made with PVC, the other ABS. I can't see any other difference though, is there any? Can they be used interchangeably?
MikeSharp01 Posted September 30, 2023 Posted September 30, 2023 PVC and ABS are very different plastics. Solvent cement is great for PVC and ABS see HERE, but you have more options with ABS See HERE although you probably don't need them if it is just for plumbing. 1
