I'm toying with this Vs Cosy for the heat pump/battery over winter. The API is simple and can be integrated with whichever control system you need via your chosen HA setup.
Plan would be to charge battery/run heatpump in the n cheapest half hour slots. You need to predict your heat demand as that determines the number of slots you need to run for. Then it's just a case of does that average price make it worthwhile. I haven't modelled it yet to get that answer.
