UVC pressure reducing valve
JohnMo
Hopefully a quick question.
Background installing an unvented cylinder. Location is remote from the cold water manifold, preventing connection of the balanced port to the cold supply.
House already has a PRV just after the stop cock set at 2.5 bar.
Cylinder comes with a combined inlet set, set at 3 bar.
Can I just blank the balanced line off?
Do I need the second PRV to comply with regs?
This falls into the realms of an UVC retro-fit. Done loads of them.
Get the PRedV at the stopcock raised to 3 bar, as at 2.5 it will be quite restrictive.
Install the control group / PRedV as per the MI's, local to the cylinder, but the one thing that all buffoons forget is to add a single check NRV to the hot outlet of the UVC.
Do that and you are 100% kosher. ;). Warranty will be intact with that all done.
