Hey All,
Some advice please.
The gas fire was removed and capped. We would like to remove the mantle/old fireplace surrounding completely and decorate.
Would a builder do the removal or could a decorater do it?
Also, guessing the middle part needs filling or does it need to be left so air flow can still go "up" or what not for the house to "breathe"/won't cause internal problems like damp our mold.
If blocking it is OK, which would be the better option...blocking it with bricks or blocking it with wood and insulation?
Any advice appreciated.  Thanks!
14 hours ago, twice round the block said:
Can you post a photo of the whole wall that the fire place is attached to taken from the other side of the room, so I can see the ceiling line as well.
hi!
Thanks.
Just have these for now. will try getting more.
Thanks again.
20 minutes ago, TryC said:
hi!
Thanks.
Thanks again.
Thank you  for the extra photos.
In your very first photo it looks as if the brickwork reveals inside the fireplace are not tied into the rear wall, and there is a void on both the left and right sides.
Is this the case?
As the surround was just for decorative purposes  I can't see a problem with a decorator removing it and making good.
I'm more concerned about the construction of the fire place and what's going on with that.
Is this the case?
hi,
I'm not sure what you mean?
the fireplace has been removed. but will check and see if I can get a better photo closer inside? would that help?
Is this the case?
hi,
I took some more photos for your kind review.
Is that a gas pipe and is it live (connected)? I would get it removed if you are blanking off the opening. The surround and the “marble” needs removing, the blocks to each side are just to reduce the “builders opening “ to the size  of the fire surround and can be left in place. Secondly is that a ventilation hole at the back of the opening to fresh air? If so you don’t need ventilation into the room like I said above.
hi,
Yes, the gas pipe has been capped, and yes, the ventilation hole connects to fresh air 😀
But does the pipe still hold gas?, it needs removing (regs as far as I am aware).
hi,
the gas is isolated both in the garage and behind the old fireplace. The pipe has a cap on the end and is also disconnected in the garage. The pipework is just left in situ incase its needed again in the future.
So the answer is no, great, I just wanted to raise it as a possible issue 👍
Hi,
thanks!
Can I please ask, was the person who capped it off supposed to provide me with any paperwork or certificate re the works done?
3 minutes ago, TryC said:
Hi,
thanks!
No but he should have been “gas safe” registered. Don’t worry about that as long as there is no gas in that pipe 👍.
