machtucker Posted July 20, 2023 Posted July 20, 2023 (edited) Morning, I have laid a patio with an Aco channel drain at one end. The slabs next to the drain have about 5mm gap and are about 5mm higher than the side of the drain. I have Sika Fastfix jointing compound to joint the patio. What is the best way to joint the drain gap? Obviously it needs to be filled properly so the water runs into it. Should I just work in the fastfix or use mortar? I have a mortar gun which I guess will make filling it easier. Any recommendations would be good. Thanks Ed Edited July 20, 2023 by machtucker
Mr Punter Posted July 20, 2023 Posted July 20, 2023 Mortar will work OK. I struggle with the gun sometimes as they can block and make me rage. Other times they are fantastic. 5mm is very narrow so a trowel may work better. 1
Andeh Posted September 8, 2023 Posted September 8, 2023 Mortar coloured cikione works well, esp as plastic acros can flex!
