Roz Posted July 11, 2023 Share Posted July 11, 2023 Is it possible to turn the water to my bathroom off from this tank cupboard? It’s been so long that I can’t remember 😂 . We ran the main water feed up to the tank and then the cold and hot came back from the tank cupboard to the bathroom and the kitchen. I think! IMG_7351.MOV Link to comment Share on other sites More sharing options...
Susie Posted July 12, 2023 Share Posted July 12, 2023 Your cold water at basin probably comes from mains as it’s drinking water and not stored. can you find the isolator for the water coming out of tank for the hot water, no use just turning off what fills it unless you want to drain it 1 Link to comment Share on other sites More sharing options...
SteamyTea Posted July 12, 2023 Share Posted July 12, 2023 Often, an easy way to check if water is from the mains is to put your thumb over the tap outlet and turn the water on. If from a tank in the loft, you can stop the water. If mains or pumped, you can't stop it. 1 Link to comment Share on other sites More sharing options...
Roz Posted July 12, 2023 Author Share Posted July 12, 2023 yes the tank is just for hot water, I just seem to remember the guys asking us to run the main cold water up to the tank cupboard before running it anywhere else. And from there I thought we asked them to put some isolators on so we could turn the water off here instead of going outside, but I can’t see which it would be 😅 i should really write things like this down!! Link to comment Share on other sites More sharing options...
