Building a manhole. Can't source any Grano Dust locally for the benching. Is it ok to use Sharp Sand instead for the benching? If so what's the ideal mix? Presume adding a bit of Febmix helps (I'm not quick enough to work with SBR)? Thanks guys.
Yes that's fine. Don't be tempted to use too much cement. Also keep it fairly dry mix, but pre-wet the surface.   All of that will keep it strong and limit cracking.
If you've got time to get it in, some fibre additive would make it even stronger.
Confession time. I don't trust my  memory, and always read what it says on the cement bag.
Just don't add a bit more
 cement for luck.. or water for convenience.
You shouldn't need building sand, as the febmix will make it workable..
