Arthur Posted June 22, 2023 Posted June 22, 2023 (edited) Hello Have ordered Rationel Alu clad doors and windows for the timber framed house. Ordered the same for Personnel door and window for the detached garage so they matched. Window Distributer has since advised that because the Rationel door and window is 123mm thick I’ll have to put a 50mm batten on the inside of the garage around the door & window as the garage is single thickness brick only (102mm) and ~30mm setback will be needed for the cill. Think this might look unsightly on the inside of the garage. Would you 1) continue with the distributors advice and go with a batten 2) cancel the Rationel garage Personnel door and window and find a upvc or al clad thinner door and window frame or 3) other solution? thanks. Edited June 22, 2023 by Arthur More clarity
Marvin Posted June 25, 2023 Posted June 25, 2023 On 22/06/2023 at 21:46, Arthur said: Hello Have ordered Rationel Alu clad doors and windows for the timber framed house. Ordered the same for Personnel door and window for the detached garage so they matched. Window Distributer has since advised that because the Rationel door and window is 123mm thick I’ll have to put a 50mm batten on the inside of the garage around the door & window as the garage is single thickness brick only (102mm) and ~30mm setback will be needed for the cill. Think this might look unsightly on the inside of the garage. Would you 1) continue with the distributors advice and go with a batten 2) cancel the Rationel garage Personnel door and window and find a upvc or al clad thinner door and window frame or 3) other solution? thanks. Hi @Arthur Well this is a case of personal opinion. I would keep the order and batten out. By the time the garage is used it probably won't notice. Others may do something else. Good luck. M
Arthur Posted June 25, 2023 Author Posted June 25, 2023 Thanks Marvin. Is that because you’d prefer the external continuity between house and garage?
