puntloos Posted June 14, 2023 Posted June 14, 2023 According to Filtered water from Quooker some (all?) quooker taps can provide both softened and direct water. Does anyone know details? Just a matter of connecting both sources, or are there snags, gotchas etc? Even if it's _possible_, next question is should you do it? I'm tempted to just do softened since it's a fragile device and limescale kills
Russdl Posted June 14, 2023 Posted June 14, 2023 For our Quooker the ‘hot’ water comes from the Sunamp which is a softened supply and only provides the hot water. The ‘cold’ is direct from the mains via a Combimate water conditioner and provides the cold water. That conditioned cold supply is what gets heated for the boiling tap and cooled/fizzed for the cold/fizzy tap. No scale build up from either supply and we’re not drinking softened water.
