Adam2 Posted June 7, 2023 Posted June 7, 2023 Need to buy a lot of these so interesting to hear any good products you've used and prices if poss. To be used on sloping terraces over single ply membrane which is laid to a fall. Probably looking like the articulating ones but not 100% sure they are needed
Adam2 Posted June 8, 2023 Author Posted June 8, 2023 Well research leads me to these as looking like OK value and reasonably substantial. Plan to use a thin rubber mat underneath each to further protect the single ply membrane.
Pocster Posted June 8, 2023 Posted June 8, 2023 1 hour ago, Adam2 said: Well research leads me to these as looking like OK value and reasonably substantial. Plan to use a thin rubber mat underneath each to further protect the single ply membrane. I use ovaeda.com Similar type of things . The price of these can add up especially if you add metal supports , brackets , screws - all the ‘special ‘ bits .
Adam2 Posted June 20, 2023 Author Posted June 20, 2023 Ahh I just realised that my search on this topic was not successful on here as I used the singular "pedestal" which didn't find the plural which was used much more! Anyway, have a load of pedestals and cracking on. I bought the extra self-adjusting heads but not sure I really like them as they introduce a small amount of movement when you walk over them. I'm using them on a 3mm rubber mat which sits on a single ply membrane over the EPS all installed to a slight fall. Any thoughts if using these without the self-leveling head is a real issue - looks like there's plenty of material to absorb the level change??? For now I've just replaced 10 pedestals so I have 2 areas and will keep walking on them both to see if I'm imagining the differences 🙂
