is the red Evostik PVA good to use onto the plywood before I apply the tile adhesive?
I also add the white Evostik Primer to the adhesive to improve its qualities.
  • 2 weeks later...
ok, I got SBR onto the floorboards.
I see there is this Mapei Fast Set and Rapidset at Wickes.
Fast Set says "Pot life 20 mins, open time 10 mins" but this is pretty much the same as rapidset.
Rapidset does not say on the description how long you can work with it but it's also 20 minutes from what I tested.
In the house the temperatures are still around 19-20 in the house and there is no . This is ridiculous to work with.
Is there any slower adhesive? There is no way to do 2/3 of a medium sized bucket (black bucket) before it sets. It's not DYI friendly at all.
ok, what else I see is this Mapei Standard Set Plus Ceramic & Porcelain Tile Adhesive Grey 10kg which dries for 24h but it's almost twice as expensive as Fast Set.
