Carrerahill Posted April 20, 2023 Posted April 20, 2023 (edited) I know some members on here have done things like this before, so I am looking for a little guidance. I want to make a sort of PV traffic light system which I can in turn use to control some loads. We do not have a cylinder so an iBoost is of no use to me, but what would be of use to me is a monitor that can switch on outputs or give us a bit of a heads up we have some spare PV to make use of. My thinking is the best way to do this would be an Arduino monitoring a CT meter or meters (mains incomer and PV), it can monitor what is going on and I can then write some code to carry out different tasks at different thresholds. Let's say I had a spare kW, I could kick in the water heater in the garage or something. I am aware things can probably be bought to do this sort of thing, but there is no fun or learning in that and as I see it the less I spend on the PV related components the better the sooner the payback! Edited April 20, 2023 by Carrerahill
S2D2 Posted April 20, 2023 Posted April 20, 2023 Check if your inverter has a local API you can call via HTTP, then you can get your export power reading for free.
Carrerahill Posted April 20, 2023 Author Posted April 20, 2023 12 minutes ago, S2D2 said: Check if your inverter has a local API you can call via HTTP, then you can get your export power reading for free. It has all these things and live monitoring via a portal etc. so I suspect that can be used indeed. Just need to tie it all up.
S2D2 Posted April 20, 2023 Posted April 20, 2023 16 minutes ago, Carrerahill said: It has all these things and live monitoring via a portal etc. so I suspect that can be used indeed. Just need to tie it all up. Can't speak for other manufacturers but the Solax portal is only updated every 5 minutes, so useless for export logic. There is a local REST API that can be called to get live data though, I call mine every 10 seconds to log the values so much better for control systems. Your Arduino can then call this rather than querying a separate CT clamp.
SteamyTea Posted April 21, 2023 Posted April 21, 2023 It is easy enough to could the LED pulses on the generation meter, then set a limit that you divert at. But where are you going to divert to if you do not have thermal or chemical storage?
Carrerahill Posted April 21, 2023 Author Posted April 21, 2023 (edited) 3 hours ago, SteamyTea said: It is easy enough to could the LED pulses on the generation meter, then set a limit that you divert at. But where are you going to divert to if you do not have thermal or chemical storage? I am going to work on that! I have some unconventional ideas. I am now thinking I need a little cylinder which I would use to preheat water going into the combi, or I might use it to charge a battery bank in a more unconventional way, i.e. a battery charger that gets powered up when export meets or exceeds typical charger demand - that sort of thing. I have a 24VDC PV system in the garage which as of yet has no load on it (only got the solar charge controller 2 weeks ago) which I am going to use to feed a small inverter and run all my garage lighting and garden/house external lighting from, so I have options. It is as much about tinkering for me as anything else. Edited April 21, 2023 by Carrerahill
