Active silicone used but instructions say neutral - shower tray. Should I be worried?
I had a shower tray replaced (previous one failed).  The fitter has used active 785 sealant and I think OB1 as well (between tray and  tiles/wall).  Instructions say that I should use neutral slicone and other types of sealants can damage the tray.
(I am so fed up with tradesmen and their shoddy work.  This tradesman is one of the better ones).
Edited by Question
I think OB1 Adhesive is probably OK. It claims to be solvent free.
There are several versions of 785. I think 785+ is an acetoxy type, 785n is Neutral. Pretty sure lots of people have used both on trays..
For some reason I can't post a link but there are people on the diynot.com form that say...
Quote
I have never had any problem using the non neutral cure version with acrylic trays. IIRC, you should not use neutral cure silicone with porous stone tiles though.
I believe that rather than adhesion with acrylic, the potential issue is the 785+ might discolour/etch the acrylic. I have never experienced that
Quote
I have tiled 30+ bathrooms, many of which had acrylic basins or shower trays. I haven't experienced any problems with the acetic acid versions.
Some people say the neutral n version sticks better.
Thanks very much.  I am getting mixed message from my research.   Neutral also seems better for wet environments.   I think my shower tray isn't acrylic.
