Hi all I’m having My front door replaced by the developer.
It’s a timber frame house.
 Is there a certain way they should be replacing the door to maintain airtightness.  Replacing airtightness tape etc?
I’m afraid they will just tear it out and use cheap foam and put a cover strip over it. To hide the damage.  Which will obviously deteriorate and become draughty .
''Is there a certain way they should be replacing the door to maintain airtightness.''
As you imply - 'properly'!!
Yes, no less tape than was there first off, and if the original taping was as cr*p as some I have seen then not so much more, as better applied. And if they go to use plastic 'plank' ask them to do a proper job.
Good luck.
