joth Posted February 26, 2023 Posted February 26, 2023 I'm planning to install a small 3 port manifold pair (flow and return) for the fan-coil units I have in the loft. The only thing is as I use these for cooling more than heating, it'd be very beneficial to get custom insulation block for the manifold, that I can wrap all joints on, to avoid condensation. The FCU can run right down to 5 deg. Any recommendations for manufacturers? I found this for HKV manifold, but never heard of them before. Worse case I can lag it with sheep wool and sticky foam and whatnot, but it'd be nice if there was a pre-made solution for this. (Or, I could build a condensate tray for it, but then I need to ensure nothing flows down the brackets onto the wall etc which maybe a long haul task.)
