I want to connect a PoE outdoor ring camera to a powerline (like this): https://www.amazon.co.uk/TL-PA4010PKIT-Passthrough-Configuration-AmazonBasics-RJ45-CAT6-Ethernet-LAN-Patch-Cable/dp/B07V2966DM/ref=psdc_429888031_t3_B01G5Q9E0O
I have seen PoE injectors that can convert an ethernet cable supplying both power and data to two separate outputs: (1) an ethernet cable with only data; and (2) a power supply. Does the reverse of this exist, and if so, what's it called?
Edited by Adsibob
  • Adsibob changed the title to PoE injector? combined with a homeplug for a Ring camera?
Sure - I've used this in my shed before to power a wireless camera that's POE only when I didn't have a nearly DC supply - use-ip did them for my Hikvision camera - have a look at the range below and see if this is what you are after then look for same in other local places:
https://www.use-ip.co.uk/level-one
Edited by mike2016
