Pocster Posted February 16, 2023 Posted February 16, 2023 I thought the gap between ceiling and structure had to be at least 30cm . Understand this requirement for timber joists etc . But if it’s a concrete ceiling ; what is the min ? ta !
MikeSharp01 Posted February 16, 2023 Posted February 16, 2023 There isn't one as far as I know, Our Building Control scrutinised drawings show a 50mm gap between the inner face of the plaster board and the inner surface of the rafters / joists and that is all the service void we have. If you have to have 30cm (300mm) everywhere rooms would be so much smaller. 1
Pocster Posted February 16, 2023 Author Posted February 16, 2023 (edited) 5 minutes ago, MikeSharp01 said: There isn't one as far as I know, Our Building Control scrutinised drawings show a 50mm gap between the inner face of the plaster board and the inner surface of the rafters / joists and that is all the service void we have. If you have to have 30cm (300mm) everywhere rooms would be so much smaller. that would explain why I couldn’t find one ! . Right ! - tighty it is ! 👍 Edited February 16, 2023 by pocster
