What's the right way to insulate a Butterfly/London roof?
It looks like this on the outside:
And this on the inside:
There's two parts I'm especially wondering about:
1. The red bit toward the bottom of the "valley", where the roof and the ceiling comes to a point. There's obviously not enough height to put a great deal of insulation here. Also, completely filling this area would block airflow.
2. The green bit that's the main rafter, at the very lowest point of the roof (under the gutter). This is cold, solid, wood bridge.
I'm planning to board up the ceiling with insulated plasterboard so all areas have some (meagre) insulation. Is it worth filling the red area with insulation, or leave it unfilled, for better ventilation?
  • 2 years later...
Hi mjsx,
I'm looking to DIY insulate a butterfly roof mid terrace in London. Did you just leave the bottom of the V without insulation? Did you add any ventilation? Thanks!
