Paul101 Posted February 5, 2023 Share Posted February 5, 2023 Hi, I need to create a doorway from the ground floor external side wall of a commercial property to the first floor (residential). I assume I have to do the following: 1. Create an opening from the ground floor external wall with lintle and door 2. Create an opening on joists of the first floor to install the staircase from inside ground floor to the first floor 3. Install staircase from inside ground floor to the first floor I was wondering how much it will cost to do the entire job. Thanks Link to comment Share on other sites More sharing options...
bassanclan Posted February 5, 2023 Share Posted February 5, 2023 £2500 1 Link to comment Share on other sites More sharing options...
Paul101 Posted February 6, 2023 Author Share Posted February 6, 2023 On 05/02/2023 at 22:24, bassanclan said: £2500 Expand Thanks, I thought the stair cases are very expensive. Link to comment Share on other sites More sharing options...
markc Posted February 6, 2023 Share Posted February 6, 2023 You say a commercial premises, will you be walling off the staircase for fire protection? 1 Link to comment Share on other sites More sharing options...
Paul101 Posted February 6, 2023 Author Share Posted February 6, 2023 No, it will be a normal staircase from the ground floor to the first floor. I am planning to convert the first floor to a flat and then I need to give a staircase. I need to create door from the ground floor area of the external wall to inside and then the staircase. That is why I am looking for the cost. Thanks, Link to comment Share on other sites More sharing options...
