Gribble Posted February 3, 2023 Posted February 3, 2023 What started out as just a summer house in the garden, has now become a bit complicated and we would appreciate some advice. It is 6m x 8m on a C25 concrete slab which has a damp proof course in it. We naively thought that was sufficient and started to build the cabin. We have the inner structure and first roof layer complete, but have now learned that we needed to put a waterproof membrane on top of the concrete beneath the wood. The only way to do this is to lever the building up a centimetre or so at a time in sections and slide oblongs of membrane in underneath the four walls, then lay a large piece over the concrete inside before screwing all the wood back down. A nightmare, I know... but it is what it is and we can't see any alternative. My question is, what dimensions do the sections of membrane need to be and how much overlap must they have to comply with building regs? We obviously don't want to be doing this again!
markc Posted February 3, 2023 Posted February 3, 2023 (edited) A few acros and jack the whole thing up. Get your perimeter done and then drop it back down and lay the inside. Any joints and overlaps need to be taped so doing in sections will be a PITA. make overlaps at least 300mm but very difficult to check after taping so the more the better … and easier Edited February 3, 2023 by markc
Gribble Posted February 3, 2023 Author Posted February 3, 2023 1 minute ago, markc said: A few acros and jack the whole thing up. Get your perimeter done and then drop it back down and lay the inside. Any joints and overlaps need to be taped so doing in sections will be a PITA. make overlaps at least 300mm but very difficult to check after taping so the more the better … and easier Thank you for your reply, it's very much appreciated. We can only lift it from beneath the walls, the nature of the build is that the wood is slotted together and uses gravity for stability, so (if I've understood you correctly) jacking up anything other than the planks of wood that are actually touching the concrete wouldn't work and would only pull the building apart. It's a reall conundrum!
Iceverge Posted February 3, 2023 Posted February 3, 2023 A few questions 1.Do you have any cross section sketches of the building? Showing the DPC etc. as built. Maybe some pics of the wall where it meets the base inside and outside. 2.Where does the ground level sit in relation to the rest of the building? 3.Is this going to be inspected be a building control inspector? 4.Have you any insulation in the slab? 5.How much head room have you allowed for internally? 6. Are you limited by the ridge height? 1
