Simon R Posted February 6, 2023 Share Posted February 6, 2023 5 minutes ago, SteamyTea said: Do you know the sampling rate? From the charts it looks reasonably fine. It's five minutes give or take. The level of detail from the GE cloud server and Octopus billing is far more detailed than I had anticipated. Link to comment Share on other sites More sharing options...
SteamyTea Posted February 6, 2023 Share Posted February 6, 2023 38 minutes ago, Simon R said: It's five minutes give or take So almost enough to show a kettle boiling. Unless it is a really large, full kettle. Link to comment Share on other sites More sharing options...
S2D2 Posted February 6, 2023 Share Posted February 6, 2023 8 minutes ago, SteamyTea said: So almost enough to show a kettle boiling. Unless it is a really large, full kettle. 49 minutes ago, Simon R said: It's five minutes give or take. The level of detail from the GE cloud server and Octopus billing is far more detailed than I had anticipated. Solax (and I believe GivEnergy too) provide a local API on some inverters so you can get whatever fidelity the inverter sees. I'm logging 10s data from mine without issue, plenty scope to see kettles on etc. Link to comment Share on other sites More sharing options...
SteamyTea Posted February 6, 2023 Share Posted February 6, 2023 35 minutes ago, S2D2 said: I'm logging 10s data from Yes, that is a good period. Mine is 1Wh or 6 seconds, which is good as I can easily calculate the zero power draw percentages. Link to comment Share on other sites More sharing options...
Simon R Posted February 6, 2023 Share Posted February 6, 2023 2 hours ago, SteamyTea said: So almost enough to show a kettle boiling. Unless it is a really large, full kettle. It certainly enough to show the kettle boiling. The spike at 14:00 was the kettle and toaster running together and pushing demand over 3.6kW ...and should not have involved grid power....should have waited for the kettle to boil. Link to comment Share on other sites More sharing options...
DragonQ Posted February 6, 2023 Author Share Posted February 6, 2023 Any other ideas for a 48V ("low voltage") battery inverter that has local data access (via modbus TCP for example)? GivEnergy's only non-hybrid inverter is 3 kW only, would prefer something slightly beefier, say 4-5 kW. Link to comment Share on other sites More sharing options...
