dave1967 Posted January 25, 2023 Share Posted January 25, 2023 Hello Looking for a solution for slow draining toilet and gurgling. Its downstairs with no vent and needs one I think as when i put a hose pipe through the toilet pan connector it solves the issue. The drain runs about 18 feet in total until it tees in with main drain about 7 to 8ft down. Currently it have a swan neck connector as drain only 5" from the wall. I cant seem to find a close fitting connector that i can fit an air inlet valve to. Any thoughts or help will be greatly appreciated. Cheers Link to comment Share on other sites More sharing options...
Mr Punter Posted January 25, 2023 Share Posted January 25, 2023 Can you install a short stack with an AAV on top and connect into that? Link to comment Share on other sites More sharing options...
ToughButterCup Posted January 25, 2023 Share Posted January 25, 2023 Thats what we (had to) do. Link to comment Share on other sites More sharing options...
dave1967 Posted January 25, 2023 Author Share Posted January 25, 2023 Dont really want a stack, sorry could i solvent weld an aav onto a swan neck? Link to comment Share on other sites More sharing options...
dave1967 Posted January 25, 2023 Author Share Posted January 25, 2023 Actually just checked again and it is positive pressure so may be a blockage further down? Link to comment Share on other sites More sharing options...
Mr Punter Posted January 25, 2023 Share Posted January 25, 2023 If you do the short stack with AAV you can include rodding access. Link to comment Share on other sites More sharing options...
dave1967 Posted January 26, 2023 Author Share Posted January 26, 2023 On 25/01/2023 at 17:31, Mr Punter said: If you do the short stack with AAV you can include rodding access. Sorted it today. Fitted 40mm offset connector and mcalpine pan connector with 32mm branch on to which i have fitted an aav. Managed to road up from the manhole and cleared a large blockage. Hopefully its sorted, only just moved in in Nov so may have been a n issue for a while. All working fine now. 2 Link to comment Share on other sites More sharing options...
