Hi all,
Looking forward to getting some top tips from those that have been here already.  Starting the journey to turn this old cow shed into something a little more habitable.
Two areas I'll be after some advice on right away are PSTP & out letting of discharge & also starting to understand Solar in a bit more detail to get specs right.  Current outline spec is SIP build / Air source underfloor / Solar / Batteries / MVHR - starting building regs & SAP side now.  Have done loads of renovations before but not a ground up build using any of the new 'renewable' tech.  We have to retain the original concrete frame for the central section but the rest is from scratch.
  • Like 4
2 hours ago, Russell griffiths said:
If you are retaining the concrete frame have you considered icf, I know there’s a couple of people on here that have done this incorporating the frame into the inner core of the icf.
a good friend has just built in ICF, hadn't particularly considered for this but can definitely explore as you describe. thanks 👍
