Hello
After a couple of days of heavy rain and high winds I notice a brown stain on a ceiling below a balcony.
It's right in the corner so I took a couple of decking planks up and saw a couple of possible problem areas (photos attached)
I'm obviously going to have it looked at but in the short term I was going to try and fill these areas and see what happens. Pulling all the decking and framing up will be a nightmare.
Where would you guys being looking at being the main problem area?
The roof is a pvc/tpo welded membrane.
Edited by Simba_ali
The split at the top isn’t good but I think your problem is drainage. Possibly leaves blocking the outlet has allowed water level to rise and find holes.
If the wind blew the leaves around and blocked the drain hole them maybe not. It looks like a tide line around the side indicating water has been up to board level.
Yea I can see what you mean, you could be right but further along it has a overflow valve which would not allow it to reach that height. I think that tide line is a combination of me cleaning the mud and the decking running muddy surface water over the sides
