Sorry for the lengthy Title, not sure how best to word it....
We are building in block on flat, with external insulation.  In 1 area, we are fitting a window, but will stud out below it, so that if in the future we want to convert it into some French doors, we can.
Any tips on how best to damp proof this?  Or, if I am planning to externally insulate across this bit too, do I even need to bother?
Thanks
Tim
I presume the block is rendered
Fix a cement board to the stud with back to back stop beads and render all Simply knock the stud out cleanly when you decide to add patios
Covered in 60mm Kingspan K5, and rendered.  So there is no additional need to damp proof, and relying on the render coats should be sufficient?
Cheers
Tim
