drcarrera Posted December 26, 2022 Posted December 26, 2022 (edited) Has anyone any experience of Ecoforest ASHPs? I've had a quote which recommends two 10kW Arotherms but with a single Ecoforest unit as a cheaper alternative. Aside from the company website I can't find anything about them, good or bad! The Vailants have a 7 year warrantee which is a plus and I guess there may be an advantage of redundancy if one breaks down but if I could be confident the Ecoforest is a decent unit it's two year warranty wouldn't be much of an issue if it saves me money over the two Vaillants! Edited December 26, 2022 by drcarrera
dpmiller Posted December 26, 2022 Posted December 26, 2022 the Ecoforest looks like it's actually rated at 13kW?
drcarrera Posted December 26, 2022 Author Posted December 26, 2022 31 minutes ago, dpmiller said: the Ecoforest looks like it's actually rated at 13kW? I assume it's this one, which is 20kW as far as I can see : https://ecoforest.com/en/products/heat-pumps/air-source-heat-pumps/ecoair-evi-4-20/
PhilT Posted December 26, 2022 Posted December 26, 2022 51 minutes ago, drcarrera said: I assume it's this one, which is 20kW as far as I can see : https://ecoforest.com/en/products/heat-pumps/air-source-heat-pumps/ecoair-evi-4-20/ top model quoted as 5-22kW. Highly impressive modulation range claimed 15%-100% looks very interesting and there's a review here https://www.fmb.org.uk/homepicks/heat-pumps/ecoforest-ecogeo-ground-source-heat-pump-review/#:~:text=Final verdict,an extension in the future.
PhilT Posted December 26, 2022 Posted December 26, 2022 52 minutes ago, PhilT said: top model quoted as 5-22kW. Highly impressive modulation range claimed 15%-100% looks very interesting and there's a review here https://www.fmb.org.uk/homepicks/heat-pumps/ecoforest-ecogeo-ground-source-heat-pump-review/#:~:text=Final verdict,an extension in the future. sorry that's a GSHP - can't find a review for the ASHP ecoAIR+ EVI 4-20 but still highly impressive if using the same technology as the GSHP
PeterW Posted December 26, 2022 Posted December 26, 2022 Spanish company that uses a mix of German and Italian parts although I am sure they are assembled in China now. Used to make some good pellet boilers - looks like they are expanding into the renewables market. @drcarrera have you had a proper heat loss and heat design done as 20kW is a lot of heat demand.
drcarrera Posted December 26, 2022 Author Posted December 26, 2022 11 minutes ago, PeterW said: @drcarrera have you had a proper heat loss and heat design done as 20kW is a lot of heat demand. I have, but quite a lot of variation between various quotes - from 14 to 20! House is around 20 years old so reasonable insulation wise and has a floor area of around 320 sq/m with high ceilings. I've estimated we use about 35000 KWh pa for heating and HW although we also have an oil Aga which complicates things. CH/HW and Aga use 54000 KWh but how much of the Aga is cooking and how much space heating is anyone's guess.
