How do you fix cement board to block work walls? i have seen various solutions such as tile adhesive / grip fill and then mechanically fixed with screws. is this the general way?
Also any ideas where to source fibre cement screws for timber walls, can't seem to find them at screwfix / toolstation
We normally use flex tile adhesive
10 mil notch on the block 10 mil notch on the Cement board Don’t forget to seal your board with SBR the day before
Some Architect's spec four BG knock ins per m2 the following day
Bit over the top really
