tommyt11 Posted November 21, 2022 Posted November 21, 2022 Has anyone managed to find an off the shelf access hatch that can be plastered up to and on top of, that is also of a high standard of airtightness AND has some level of insulation incorporated? I am doing a basement conversion that has service hatches to rest of ground floor underfloor crawl space; house will be fixed up with oodles of insulation and MVHR hence I need something good here. In the absence of finding something off the shelf I will just get a well-gasketed plasterable hatch then inside it fix up a PIR inside a 3x2 carcass that can be screwed or similar to the inner reveal (which will be quite deep). Thanks, Tom
Marvin Posted November 21, 2022 Posted November 21, 2022 Hi @tommyt11 Often have had to buy a regular one and insulate it! Or on the last 2, build my own, and insulate them, and air tightness by compressing a gasket on the door stop and fixing shut by a latch or two.... Good luck M
