irnbru Posted November 17, 2022 Share Posted November 17, 2022 Hi everyone! Right now I struggle to understand how the flow rate in each room is controlled. For example, let's suppose that the supply flow rate is 200m3/h, and the supply ducts goes to different rooms, like living room, bedroom, etc. How do I make sure that the air flow rate at each room terminal is the desired flow rate? Imagine that I want to supply 30m3/h of fresh air to my room while 40 m3/h to the room next to me, how is that difference in flow rate controlled? I'm using MVHR radial arrangement. Link to comment Share on other sites More sharing options...
dpmiller Posted November 17, 2022 Share Posted November 17, 2022 there's a damper or restrictor either at each room terminal or in the manifold. Have you bothered to look at any suppliers websites yet? Link to comment Share on other sites More sharing options...
irnbru Posted November 18, 2022 Author Share Posted November 18, 2022 3 hours ago, dpmiller said: there's a damper or restrictor either at each room terminal or in the manifold. Have you bothered to look at any suppliers websites yet? Thank you! Yes, I have looked, but personally I find them rather unclear. Link to comment Share on other sites More sharing options...
Kev Y Posted December 1, 2022 Share Posted December 1, 2022 This really a job for somebody who understands the importance of balancing flow rates and the relevant BuildingRegs. The valves in each room can be adjusted, therefby affecting flow to other valves, until each meets the required flow rates Link to comment Share on other sites More sharing options...
