Ambaz79 Posted November 14, 2022 Posted November 14, 2022 Hello I have already purchased our MVHR unit and need to order everything after this point. I need around 500M of 75mm Semi Rigid Ducting and 2 Manifolds ideally a 15 and a 20 outlet version. I cant seem to find a 20 so may have to split it in to 2 x 10s. I also need around 22 plenums. I have got quotes from BPC aswell as Blauberg but just wanted to know if there is anyone else I should be getting quotes from?
Conor Posted November 14, 2022 Posted November 14, 2022 Lindab. That's a lot of ducting and outlets, I'm hoping you've got two units for that or a big one with decent sized main ducts. You would definitely need to split that in to four manifolds, each fed by a 160mm duct back to the unit(s). You'll find that might also reduce your individual runs as you'll split the locations of the manifolds to be more central.
Ambaz79 Posted November 14, 2022 Author Posted November 14, 2022 Hi Conor, Ive got the same unit as the Lindab XHBQ 1000 However I got this direct from the factory as I do other business with China. Tried to get this locally but a unit of this size was just too costly. Seems like a beast of a unit with 250mm outlets. so I will run 250mm ducting to the manifolds that will downsize to the manifold requirement. Do you know the best place to buy Lindab products?
Conor Posted November 14, 2022 Posted November 14, 2022 Directly from Lindab, give your local sales rep a call and they should be able to sort you out. Details on the website somewhere I think. You don't need to be trade. Yeah, you'd run 250mm out of the unit, branch off to the manifolds at 160mm per manifold. You'll need a LOT of room for this equipment!
Ambaz79 Posted November 14, 2022 Author Posted November 14, 2022 Great ive got the Leicester Contact for Lindab and have emailed them my reqyuirements. Thanks for your help on this.
