Hi,
Been laying out some of the pipework for the ensuite log flume.
Before I clamp/fix it in place, can I do this?  Can I have this amount of fall in such a short space?  Want to make sure all passengers reach their destination 🤣
Is the bottom bend welded or very well fixed? If not the passengers could force their way out after hitting the wall repeatedly.
All pipes are pushed well into the stops, and into the downpipe which has a couple of fixings, a couple more to be added when I next go shopping for supplies...  There is no movement, other than the bit on the slope which will be fixed down, if deemed ok.
I'm pondering over the run for log flume no2  And I was pondering how to get my 50mm shower, sink and bath water into the soil pipe before the pipes exit the building.  The pipes will be dropped between pozi' joists under the flooring and there is not much in the way of a vertical drop where I can tap into before the pipework goes into the main stack outside, I'm not sure I really want to tap into the 110 on the horizontal run.  And ideally I only want one pipe exiting the building.  I was browsing through threads and came across this thread where a 110mm to 50mm reducer was used to allow a feed into the 110 soil pipe.
I've attached a proposed pipe layout below and where I'd like to use the reducer into a solvent weld 135 branch.  Can anyone see any issues doing this?
