crispy_wafer Posted November 6, 2022 Posted November 6, 2022 Today, I've been playing with MF... My C Studs came in at 3.6m lengths, I'm got loads of 1.2m bits left over, can I join these together and use as studs, rather than picking up a new stud all the time, or is that a bit of a no no, if I can join them together, what's the best way to do so? ta.
PeterW Posted November 6, 2022 Posted November 6, 2022 12 minutes ago, crispy_wafer said: can I join these together and use as studs Yep - take a piece of C-Stud and turn it over so it’s resting on the edges and use a bolster to put a bend in the back. Then flip that inside the two pieces you want to join and put a couple of wafers either side. You can also use it up for noggins 1
