Labour cost for fitting timber cladding?
Moonshine
I paid about £6.5k labour iirc. We bought 4130lm of a mix of charred larch and standard Siberian larch so that’s about £1.57/lm I think!
hope that helps. Although I think our chippie has put his daily rate up a bit since he finished our job so might’ve cost us a bit more if we were doing it now.
Cheers, that does look a cheap rate and can understand why his rates went up.
My thoughts were about £3 per l/m, which is £24 per m2 on 150mm larch (125mm coverage)
yeah, I was very happy with his quote and work! he was a one man band (with an occasional helper/labourer) so it took quite a while but that wasn't an issue for us as we're definitely not a speedy build.
I ended up taking a day off doing some of the cladding. In about 6.5 hours I did about 68 linear metres and a window trim.
Working solidily, treating cut ends and laser leveling every couple of lifts, so not rushing it too much.
On my own experience £3 may be a tad rich
photos? 🙂
On 10/11/2022 at 21:17, Thorfun said:
I wish you the best of luck!
I did a solid side of the building the other day, straight runs without any windows / doors, managed 80 linear metres in 3 hours, treating cut ends and laser levelling every couple of lifts.
At £25 / h that's less than £1 a metre 😁
