behind a tv  to hopefully stop the heat from the twin wall pipe .  STS seems to be a lot cheaper in Wickes but would prefer the best for the job.
Edited by vix2000
I don't understand the question. Vitcas is a fire resisting board. Sts is a tile backer.
If it is to act as a thermal barrier then insulate the pipes.
If a retrofit then the one with foam in it should have more insulation.
